Süttida võivad Range Rover-id
Uudised Eestist ja laiast maailmast.
Range Rover and Ranger Rover Sport recalled for fire risks
Two separate issues may lead to underhood flame-ups, Land Rover says
BYRON HURD
Apr 10th 2023 at 10:44AM
Land Rover is recalling several model years of the Range Rover and Range Rover Sport along with the 2023 Range Rover V8 to address two issues that may lead to underhood fires. The first (and larger) of the two recalls covers plug-in hybrid variants of the 2018-2022 Range Rover and Range Rover Sport. The second recall covers just a single car — a lone Range Rover — that apparently left the factory without a critical turbo oil drain gasket.
The 2018-2022 PHEV issue is by far the more urgent of the two. Land Rover says 2,300 examples may have shipped with water pumps whose drive belts can become damaged, leading to potential failure of the pump pully. Whether this results in an immediate catastrophic failure of the pump or merely a loss of coolant circulation, the resulting overheating condition can lead to additional problems, up to and including a full-fledged conflagration.
"A concern has been identified on Jaguar Land Rover 4-cylinder petrol PHEV engines where the water pump pully drive belt can become damaged leading to detachment or destruction. Where water pump pully drive is lost, this leads to a loss coolant flow in the engine. The lack of coolant flow can cause the engine to rapidly overheat, and subsequently ruptures an engine mounted plastic elbow in the cooling circuit," Land Rover's defect notice said. "If the coolant elbow is ruptured, this leads to a coolant leak onto the turbocharger heat shield which may lead to a fire in the engine bay which can propagate to the whole vehicle."
The issue being addressed on the 2023 Range Rover stems from oiling rather than cooling, but the result can be the same if the problem is left unchecked.
"A concern has been identified on one 4.4L V8-cylinder Gasoline Engine, fitted to a Land Rover Range Rover vehicle where a gasket has been miss-fitted or is missing from the turbo oil drain pipe," Land Rover's defect notice said. "A miss-fitted or missing gasket from a turbo oil drain pipe may result in an oil leak. Leaked oil can come into contact with the exhaust manifold, which may lead to a fire in the engine bay."
Notifications for both issues should be distributed to customers starting in April.
Related video:
https://www.autoblog.com/2023/04/10/ran ... ex1DUUGgac
