Mälumäng - LR teemadel!
The 4.2 L engine had a displacement of 4,197 cc (256.1 cu in), and used the crankshaft castings from the failed "Iceberg" diesel engine project.
Myller
Postitus Postitas Myller »
LR90, link oli õige. Landy leidis ka õige copy-paste. Tegu on untsuläinud V8 diisli projektist pärit osaga.
kalev
Ma viisaka vanainimesena :oops: annan järje Landyle üle :)
LR90 kirjutas:Ma viisaka vanainimesena :oops: annan järje Landyle üle :)
Millisesse Araabia riiki plaanis Land Rover 2003. aastal ehitada oma koostetehase?
Invetseeringu suuruseks plaaniti 70 millionit USD ja tootmismahuks plaaniti 10000 autot.
tyybel
Postitus Postitas tyybel »
landy kirjutas: Millisesse Araabia riiki plaanis Land Rover 2003. aastal ehitada oma koostetehase?
Jordaaniasse. Ja kokku taheti panna Defekaid.
"olematu auto" +372 5074010
tyybel kirjutas:
Allah olgu sulle armuline ning jutt täiesti õige. Anna tuld!
tyybel
Bowler, mis ehitab kõrberallide jaoks Land Rover sportautosid, varustab oma Wildcat ja Nemesis mudelid kinnijäämiste puhuks vintsi asemel ühe teise abivahendiga. Millega?
An optional feature offered by Bowler was a lift device that could lift the vehicle past the lowest travel of the front and rear suspension. The lift was intended to be used to assist in digging the vehicle out of soft ground or to facilitate changing a wheel. The lift device consisted of a large steel plate on a hinged sub-frame attached to the underside of the vehicle frame between the front and rear axles. The lift was lowered by a hydraulic ram that was controlled from inside the vehicle. The lift plate also served to protect the underside of vehicle when raised.
hüdro tungid ees ja taga, mis tõstsid rattad pehme seest välja :oops:
http://www.youtube.com/watch?v=TLvDqp1U ... re=related
tyybel
LR90 kirjutas:An optional feature offered by Bowler was a lift device that could lift the vehicle past the lowest travel of the front and rear suspension. The lift was intended to be used to assist in digging the vehicle out of soft ground or to facilitate changing a wheel. The lift device consisted of a large steel plate on a hinged sub-frame attached to the underside of the vehicle frame between the front and rear axles. The lift was lowered by a hydraulic ram that was controlled from inside the vehicle. The lift plate also served to protect the underside of vehicle when raised.
No pms võib vist õigeks lugeda. Tegemist ka põhjkaitsme rolli täitva terasplaadiga, mis (mitte eest ja tagant aga keskelt) vajadusel kõhu alla välja sirutatakse ja siis peaks auto üles tõstma. Ka ratast on nii ilmselt päris kiire/mugav vahetada. Mudast selline asi ilmselt välja ei too aga liivasel pinnasel saab sandtrackid v sillad küll labida abita alla.
http://www.bowler-offroad.com/Nem_2009/ ... m_anim.htm
http://www.bowler-offroad.com/RAIDRAMLIFT%20ANIM2.html
Ootame uut küsimust :roll:
http://www.adrianstomcat.co.uk/Images/O ... 4x4-01.jpg
mis asi see on ja millel ta baseerub?
D90 le ehitatud elektriauto?
totu kirjutas:D90 le ehitatud elektriauto?
Ei!
Valge Hiir
Fire Control
Fire Control
Baseerub valdavalt RRC käiguosal, fiiber-klaas kere. Spetsi järgi kas 3 käiguline automaat või 5 käiguline manuaal käigukast.
Tootja Mills Extreme Vehicles Ltd (millest ka mudeli nimi MEV 4x4).
Viimati muutis Valge Hiir, T Mär 16, 2010 21:52, muudetud 1 kord kokku.
Mud Yourself!
In mud since 1999.
Õigust räägid, Sinu kord :)
ps: tagamootoriga ( selle jätsid mainimata).
http://www.adrianstomcat.co.uk/MEV4x4.htm
Valge Hiir
Fire Control
Fire Control
Kes või mis, kellelt või millelt on pildil?
Mud Yourself!
In mud since 1999.
