Mis õli
Mait07
Mis õli
Postitus Postitas Mait07 »
Küsimus siis järgmine, hakkaks õli vahetama(mootoris), aga mõistus munadega triiki :D mida sinna sisse valada??? Autoks siis Disco II ´00 ja läbisõiduks näitab 120 tuh(hästi ei usu, aga hohh.....)Valida on hetkel carlube;shell;valvoline;mobil ja kõik oleks täissündid ja 5w40.
Ja teine küsimus kuskohast otsida õlivanni tihendit ja õlipumba polti.
Andke palun ohmule nõu :oops:
tyyp07
Off-Road entusiast
Off-Road entusiast
Postitus Postitas tyyp07 »
Siin siis õli soovitus ja täpsed margid: http://www.castrol.com/castrol/sectionb ... Id=7073092
Ülejäänud vidinaid võid küsida http://www.allmakes.ee
Engine (DT) EDGE 5W-30 (a) 7.2
Magnatec 5W-30 A1
Manual Transmission Syntrans Multivehicle 75W-90 2.7 (b)
Automatic Transmission Transmax Dex III Multivehicle 9.8 (b)
ATF Dex II Multivehicle
Differential Universal 75W-90 1.7 (c)
Axle EPX 80W-90
Coolant (50%) - (d) 11.5
Brake Fluid - (e)
Grease Points Multipurpose Grease
a. Engine oil viscosity recommendations TD5 (Storm) diesel engines and V8 petrol engines from 2002: -30°C to 35°C, 5W-30; -30°C to 40°C, 5W-40/5W-50; -20°C to 35°C, 10W-30; -20°C to 40°C, 10W-40/10W-50; 0°C to 40°C, 10W-60; refer to individual model handbook for early models
b. Transfer box LT 230/230Q: 2.3 ltr, Universal 75W-90 / Axle EPX 80W-90. Models prior to Jan 98, Universal 75W-90
c. Differentials front and rear
d. Cooling systems. Use Antifreeze at a concentration of 50% or one part Antifreeze with one part water. Ethylene glycol antifreeze using organic acid technology inhibitors only recommended
e. Manufacturer's recommendation, Refer to main dealer
1. Power steering (where fitted): Current models, Transmax Dex III Multivehicle / ATF Dex II Multivehicle; older models, Refer to Technical. Discovery II, Discovery III 2002, Range Rover 2002; use only recommended fluids. Fluid is dyed green and used in common reservoir with ACE system where applicable.
Engine - Miles Max 6000
Engine - Km Max 10000
Engine - Months Max 6[/url]
Defender 110, 2000a
Suzuki Samurai 413, 1990.
http://www.rgb.ee
Kert
53449661
User Manual ütleb:
Engine-.8,2L Sobivad ACEA A1, B1 hja B2 õlid 5W30, 5W40, 5W50, 10W40 sõltuvalt sellest mis regioonis autot kasutatakse.
Mait07
Aga mis juhtub kui sisse valada A3,B4? Kas Mobil 3000 x1 5w40 API SM/SL/SJ/CF, ACEA A3B4 sobib?
