LR/RRS TDV6 2005-2009 tehase recall
Postitatud: R Juul 20, 2018 11:58
Postitas Klaabu
Kas keegi on kokkupuutunud tehase tagasi kutsumisega seoses piduri võimentisse sattuva mootoriõliga. Sellest tulenevalt kaovad pidurid järk-järgult ära. Või õigemini pidutivõimendi ei tööta enam.
Selline asi siis.
Product description
Vehicles produced between November 2005 and April 2007 (Discovery 3 vehicles LA367110-LA440000 and Range Rover Sport LS929086-LS117000).
Vehicles produced between May 2007 and June 2009 (Discovery 3 vehicles LA440001-LA513325 and Range Rover Sport vehicles LS117001-LS215618).
Identifying features
Campaign number: P017
Target number: 5441
What are the defects?
Discovery 3 vehicles LA367110-LA440000 and Range Rover Sport LS929086-LS117000.
Oil may migrate from the engine driven vacuum pump and collect in the brake booster.
This may cause a progressive loss of brake assistance, resulting in hard brake pedal and increased stopping distances for the same pedal effort. In extreme cases engine oil may migrate from the brake booster to the brake master cylinder which may lead to a loss of one or both of the foundation brake system hydraulic brake circuits. This therefore may lead to increased brake pedal travel, increased stopping distances and, in the event of both primary and secondary brake master cylinder seal failure, a total loss of service brakes.
Igatahes tekkis mul sama asi oma RRS-il(2005). Helistasin esindusse ja selgus ,et see kampaania täiesti toimib ja vahetatakse jupid välja(pidutivõimendi ja mingid jubinad veel).
Re: LR/RRS TDV6 2005-2009 tehase recall
Postitatud: R Juul 20, 2018 15:24
Land Roveril ongi nii,et otsest sõiduohutust puudutavd tagasikutsed ei aegugi. Ineseer näiteks käis mõni aasta tagasi Range Rover Calssicuga (!!!) miksit turvaapadja andurit vahetamas tagasikutse korras.
Miskid teisejärguslised tagasikutsed on aga limiteeritud kestvusega.
Siit leaia kõik Land Rover-ide tagsikutsumised ( recall) alates 1992. a.
http://www.dft.gov.uk/vosa/apps/recalls/default.asp?tx=" onclick="window.open(this.href);return false;
NB! Osad tagasikutsed on aegumatud!
