Webastole kell ja pult külge
Taavi240
Postitus Postitas Taavi240 »
Ei hakanud uut teemat tegema:
Kas, kus, kes ja mis raha eest webastole kell ja pult külge pannakse?
Aitäh,
mihkelsoo
Postitus Postitas mihkelsoo »
Huvitaks ennastki.
Renek
Postitus Postitas Renek »
löön ka kampa,
Peaks saama lisada, kuna osadel müügis lolevatel D3-del on Webasto kell lisatud käsipiduri nupu juurde.
Disco4 2011 3.0 HSE
Disco3 2008 2.7 HSE
Renek
Seda friika lehte olen näinud, sealt sain ka idee. Kuid kas D3-me puhul on asi nii lihtne.
Kui eelmisel aastal küsisin Webasto maaletoojalt (autoekspert) siis vastus oli ümmargune 0, nemad ei paigalda ja ka siis kui Inchcape on enne ümber programmeerinud ei suutvad nad midagi teha vaja veel mingeid LR orignaal lisavidinaid.
Nüüd tuhnides interneti avarustes, leidsin sellise koodiga jubina WEBASTO FBH TIMER KIT 1533 FOR LANDROVER DISCOVERY 3
Discovery 3 Engine: 2.7L(TDV6) Diesel
VIN-range: 5A300167 Onwards
Range Rover Sport (LS) 2007- Engine: 3.6L(TDV8) Diesel
Markets: Russia only
Section: 412-02b
Summary:
A customer may report a concern of poor engine starting in ambient temperatures below -25°C.
Cause: The Discovery TDV6 diesel engine is specified to start at ambient temperatures of -25°C and above. In Russia, the vehicles can experience temperatures below this threshold.
Action: On a customer concern basis only regarding the above, refer to the Service Procedure detailed in this bulletin to install an auxiliary heating timer to the fuel fired booster heater (FFBH), which provides additional engine pre-heat prior to starting. The procedure calls for the use of a special tool (LR-130) when drilling holes in the interior lamp unit. The tool is available free of charge for the first tool order (subsequent orders for the tool will be chargeable) from SPX Service Solutions via the contact details below:
(details removed)
Parts Required:
Description Part Number Quantity
Engine pre-heater timer kit JEC501490 1
Webasto tootja leht pakub ainult Friikale antud kiti.
Helistasin Autoexperti ja ootan nüüd vastust, telefoni teel sain nii palju targemaks, et kunagi pakuti kuid nad ei ole kindlad kas enam saab seda lisa Disco 3-le.
Täiendatud
Venemaal müüakse neid kite endiselt, http://lr-mag.ru/catalog.html?itemid=15 ... =JEC501490
Viimati muutis Renek, R Sept 20, 2013 09:27, muudetud 1 kord kokku.
Disco4 2011 3.0 HSE
Disco3 2008 2.7 HSE
muhlui
Postitus Postitas muhlui »
Küsige sealt
Üllar Kütt
>> OÜ BWE juhataja
>> tel. +372 525 5243
>> www.eelsoojendid.eu
Taavi240
Mõtlesin, et nüüd, kus on jupp aega möödas, kirjutan oma kogemustest webastole "kella" lisamisega:
Üldiselt võib öelda, et Tallinnas läks otsimisega üsna kaua aega, sest enamus kohad ütlevad: " Jah, saab ikka! Mis auto teil on? Discovery!..noo, me päris kindlad ei ole, aga võime proovida!"
Lõpuks leidsin sellise koha nagu www.carholding.ee ning sai peale pandud danhaus'i gsm controller.
Kauplema ei hakanud ning koos käibega oli 687eur.- (ilmselt ei ole saladus).
Oli algul mure, et kliima ei lülitunud ümber tavareziimile pärast auto käivitamist, kuid see mure sai lahendatud.
Paraku ilmes ka pärast seda, et webasto põleti oli läbi ning see sai inchape'is vahetatud 550euri eest.
Ühesõnaga, nüüd asi toimib, kuid talve ei ole, rsk!
mihkelsoo
Taavi240 kirjutas:Mõtlesin, et nüüd, kus on jupp aega möödas, kirjutan oma kogemustest webastole "kella" lisamisega:
Siukse raha eest ma võin ise tulla igal hommikul su autot käivitama (ja lume võin ka maha lükata) :)
007
Mu elus pole muid autosid!
Postitus Postitas 007 »
... sad but true ... "money talks, bullshitt walks" ... paraku 8)
Eskimo
Postitus Postitas Eskimo »
Kas suure otsimise peale puldiga varianti ei pakkunud keegi? Oleks just puldiga variandist huvitatud, mitte GSMist.
Heikki
Tunneb LR hingeelu!
Postitus Postitas Heikki »
Tere!
Panen ka siia üles Webastoid puudutava info, mida sai käsitletud Range Roverite ja Discode alamrubriikides.
Tartu LR töökojas oleme Webasto lisasoojendusi seisusoojendusteks teinud erinevates variatsioonides. Kasutame Webasto osasid ja tarvikuid. Kõige soodsam lahendus maksab 460€ ja süsteemi juhib autosse paigaldatud programmkell. Sellest moodsam ja mugavam on Webasto juhtimine puldiga, hind 770€. See ei ole lihtsalt on-off pult, vaid displayga suhtlusvahend auto ja peremehe vahel. Ja veel täiuslikum versioon on käivitamine mobiiltelefoniga, hind 850€ + SIM kaardi maksumus. Eelsoojenduse lülitumisel hakkab madalatel pööretel tööle ka salongi soojenduse ventilaator, mis esiklaasi puhtaks puhub. Kui klient seda ei soovi, paneme süsteemi tööle ilma ventilaatorita. Töö teostamine võtab aega sõltuvalt valitud süsteemist 4-6 tundi. Enne Webasto täiustamist lisavidinatega kontrollime ära kogu olemasoleva süsteemi laitmatus töökorras olemise. Rikkis süsteemi ei sunni lisaseadmed tööle ka kõige parema tahtmisega.
Juhul, kui ei ole soovi kellasid-pulte-mobiilivastuvõtjaid juurde lisada, aga lisasoojendus tõrgub, vaatame ahju üle ja teeme korda ning sooja tuleb jälle.
Liiast pole korrata, et mootor, mis ei saavuta ettenähtud töötemperatuuri, kulub ise intensiivsemalt, kulutab palju kütust ja ka teie närve auto külma salongi ja läbipaistmatute klaasidega Idea
Heikki
_________________
"Inglise džentelmenide" kohtumispaik Tartus. Professionaalne diagnostika, hooldus ja remont. TEL: 56883950, 55993078
Taavi240
Eskimo kirjutas:Kas suure otsimise peale puldiga varianti ei pakkunud keegi? Oleks just puldiga variandist huvitatud, mitte GSMist.
carholding pakkus ka puldiga varianti. Täpset hinda küll ei mäleta, kuid mu meelest oli natukene odavam, kui gsm mooduliga versioon.
