Postitatud: N Sept 19, 2013 11:00
Postitas Taavi240
Ei hakanud uut teemat tegema:
Kas, kus, kes ja mis raha eest webastole kell ja pult külge pannakse?
Aitäh,
Postitatud: R Sept 20, 2013 07:09
Postitas mihkelsoo
Huvitaks ennastki.
Postitatud: R Sept 20, 2013 07:24
Postitas Renek
löön ka kampa,
Peaks saama lisada, kuna osadel müügis lolevatel D3-del on Webasto kell lisatud käsipiduri nupu juurde.
Postitatud: R Sept 20, 2013 07:58
Postitatud: R Sept 20, 2013 08:46
Postitas Renek
Seda friika lehte olen näinud, sealt sain ka idee. Kuid kas D3-me puhul on asi nii lihtne.
Kui eelmisel aastal küsisin Webasto maaletoojalt (autoekspert) siis vastus oli ümmargune 0, nemad ei paigalda ja ka siis kui Inchcape on enne ümber programmeerinud ei suutvad nad midagi teha vaja veel mingeid LR orignaal lisavidinaid.
Nüüd tuhnides interneti avarustes, leidsin sellise koodiga jubina WEBASTO FBH TIMER KIT 1533 FOR LANDROVER DISCOVERY 3
Discovery 3 Engine: 2.7L(TDV6) Diesel
VIN-range: 5A300167 Onwards
Range Rover Sport (LS) 2007- Engine: 3.6L(TDV8) Diesel
Markets: Russia only
Section: 412-02b
Summary:
A customer may report a concern of poor engine starting in ambient temperatures below -25°C.
Cause: The Discovery TDV6 diesel engine is specified to start at ambient temperatures of -25°C and above. In Russia, the vehicles can experience temperatures below this threshold.
Action: On a customer concern basis only regarding the above, refer to the Service Procedure detailed in this bulletin to install an auxiliary heating timer to the fuel fired booster heater (FFBH), which provides additional engine pre-heat prior to starting. The procedure calls for the use of a special tool (LR-130) when drilling holes in the interior lamp unit. The tool is available free of charge for the first tool order (subsequent orders for the tool will be chargeable) from SPX Service Solutions via the contact details below:
(details removed)
Parts Required:
Description Part Number Quantity
Engine pre-heater timer kit JEC501490 1
Webasto tootja leht pakub ainult Friikale antud kiti.
Helistasin Autoexperti ja ootan nüüd vastust, telefoni teel sain nii palju targemaks, et kunagi pakuti kuid nad ei ole kindlad kas enam saab seda lisa Disco 3-le.
Täiendatud
Venemaal müüakse neid kite endiselt,
http://lr-mag.ru/catalog.html?itemid=15 ... =JEC501490
Postitatud: R Sept 20, 2013 09:10
Postitas muhlui
Postitatud: R Sept 20, 2013 12:24
Postitatud: T Jaan 07, 2014 19:33
Postitas Taavi240
Mõtlesin, et nüüd, kus on jupp aega möödas, kirjutan oma kogemustest webastole "kella" lisamisega:
Üldiselt võib öelda, et Tallinnas läks otsimisega üsna kaua aega, sest enamus kohad ütlevad: " Jah, saab ikka! Mis auto teil on? Discovery!..noo, me päris kindlad ei ole, aga võime proovida!"
Lõpuks leidsin sellise koha nagu
www.carholding.ee ning sai peale pandud danhaus'i gsm controller.
Kauplema ei hakanud ning koos käibega oli 687eur.- (ilmselt ei ole saladus).
Oli algul mure, et kliima ei lülitunud ümber tavareziimile pärast auto käivitamist, kuid see mure sai lahendatud.
Paraku ilmes ka pärast seda, et webasto põleti oli läbi ning see sai inchape'is vahetatud 550euri eest.
Ühesõnaga, nüüd asi toimib, kuid talve ei ole, rsk!
Postitatud: T Jaan 07, 2014 21:50
Postitas mihkelsoo
Taavi240 kirjutas:Mõtlesin, et nüüd, kus on jupp aega möödas, kirjutan oma kogemustest webastole "kella" lisamisega:
Siukse raha eest ma võin ise tulla igal hommikul su autot käivitama (ja lume võin ka maha lükata)
Postitatud: K Jaan 08, 2014 18:07
Postitas 007
... sad but true ... "money talks, bullshitt walks" ... paraku
Postitatud: E Jaan 20, 2014 23:37
Postitas Eskimo
Kas suure otsimise peale puldiga varianti ei pakkunud keegi? Oleks just puldiga variandist huvitatud, mitte GSMist.
Postitatud: E Jaan 20, 2014 23:55
Postitatud: T Jaan 21, 2014 11:56
Postitas Heikki
Tere!
Panen ka siia üles Webastoid puudutava info, mida sai käsitletud Range Roverite ja Discode alamrubriikides.
Tartu LR töökojas oleme Webasto lisasoojendusi seisusoojendusteks teinud erinevates variatsioonides. Kasutame Webasto osasid ja tarvikuid. Kõige soodsam lahendus maksab 460 ja süsteemi juhib autosse paigaldatud programmkell. Sellest moodsam ja mugavam on Webasto juhtimine puldiga, hind 770. See ei ole lihtsalt on-off pult, vaid displayga suhtlusvahend auto ja peremehe vahel. Ja veel täiuslikum versioon on käivitamine mobiiltelefoniga, hind 850 + SIM kaardi maksumus. Eelsoojenduse lülitumisel hakkab madalatel pööretel tööle ka salongi soojenduse ventilaator, mis esiklaasi puhtaks puhub. Kui klient seda ei soovi, paneme süsteemi tööle ilma ventilaatorita. Töö teostamine võtab aega sõltuvalt valitud süsteemist 4-6 tundi. Enne Webasto täiustamist lisavidinatega kontrollime ära kogu olemasoleva süsteemi laitmatus töökorras olemise. Rikkis süsteemi ei sunni lisaseadmed tööle ka kõige parema tahtmisega.
Juhul, kui ei ole soovi kellasid-pulte-mobiilivastuvõtjaid juurde lisada, aga lisasoojendus tõrgub, vaatame ahju üle ja teeme korda ning sooja tuleb jälle.
Liiast pole korrata, et mootor, mis ei saavuta ettenähtud töötemperatuuri, kulub ise intensiivsemalt, kulutab palju kütust ja ka teie närve auto külma salongi ja läbipaistmatute klaasidega Idea
Heikki
_________________
Postitatud: K Jaan 22, 2014 21:35
Postitas Taavi240
Eskimo kirjutas:Kas suure otsimise peale puldiga varianti ei pakkunud keegi? Oleks just puldiga variandist huvitatud, mitte GSMist.
carholding pakkus ka puldiga varianti. Täpset hinda küll ei mäleta, kuid mu meelest oli natukene odavam, kui gsm mooduliga versioon.
