lihtne diff lukk
Kas pole märganud aga kesklukuga mingeid kiiruse piiranguid ka on või mitte?? Ma olen aru saanud et pole nagu
Discovery II ja IIA
If you have the diff lock stud on your unit you will only require the linkage parts, to determine this you will need to find the transfer case serial number and check it starts with
41D LT 230SE
42D. LT 230SE
If it starts with
61D
62D
69D
70D
then you will need the diff lock parts to go in the transfer case.
vaata lisaks http://www.aulro.com/afvb/good-oil/39956-cdl-d2s.html
