ARK+EW/EU seadused ja LR raami vahetus
Postitatud: R Okt 31, 2008 23:47
Lugedes seda:
http://forum.4x4.ee/viewtopic.php?t=13657
tekkis küsimus, kas meil on võimlik legaalselt auto alusraami vahetada (kui raam ostetud ametlikult ja paberitega)? Osades EU maades saab.
Pole jõudnud väga meie banaanivabariigi seadustesse sukelduda.
Postitatud: N Nov 13, 2008 12:56
Postitas tt
koopia 4x4 foorumist:
mina küsin:
Is there any paperwork required in UK? New chassis number etc? Do you have to show the car in DVLA before/after?
Also could you scan and post here any certificates & paperwork included with new chassis?
Just wondering, could we do that legally in Estonia, our DVLA is quite strict in that matter - VIN and chassis numbers have to match.
emamaalt vastatakse:
you can order the replacement chassis stamped with your existing chassis number, because its a direct replacement (not modified) theres no problem doing this officially. Trevor kept the piece of the original chassis that had the numbers stamped on so he can prove (if anyone official ever asks) that the old chassis had been destroyed.
The replacement chassis is so good the only difference is the galvanising (and the fact its construction is corner welded instead of 2 "C" sections) The replacement chassis can be ordered in different thicknesses if you want something stronger (heavier) or you can order a coil sprung 88" chassis for a series Landrover allowing you to change to Range Rover/Discovery/Defender axles and suspension.
There are no certificates that come with the new chassis but there is a receipt and this can show that your exisiting chassis number has been stamped in (if you want). Its a pretty normal thing to do here, it helps the car keep a good value if its not rusty! Very Happy
Kokkuvõtteks saab raami tellides teatada oma vana kerenumbri mis stantsitakse uuele raamile.
Mida ütleb sellepeale ARK? Ehk kommenteerite kui, te seda foorumit niikunii igapäevaselt loete. Foorumisse postitamiseks peab end kasutajaks registreerima,
kasutajaks saab registreerida siin.
Postitatud: N Nov 13, 2008 13:12
Postitas LR90
Kui uus raam tuleb vana VIN- koodiga, milleks
Sa sinna ARK-i pead minema
Postitatud: N Nov 13, 2008 13:39
Postitas tt
LR90 kirjutas:Kokkuvõtteks saab raami tellides teatada oma vana kerenumbri mis stantsitakse uuele raamile.
Sain aru, et raami tegijad on kolmas partei, pakuvad soovikohast raaminumbrit lisateenusena.
ARK -i angaari leivanumber ju LR raami nähes silmad punni ajada: issand jumal KEEVITATUD raam!!! Seleta siis neile, et sellised nad on aegade algusest olnud
Postitatud: N Nov 13, 2008 13:43
Õige point. Seega, kui VIN-koodi plaat ja raaninumber klapivad on kõik legaalne. Raam nagu iga teine varuosa.
Postitatud: N Nov 13, 2008 13:46
Postitas tt
Aga raamivahetus generaalselt - teised margid, suvalise numbriga või numbrita raam? Selle kohapealt pole me veel targad.
Aga hea teada, et Emamaal selline kasutajasõbralik teenus olemas on
eriti popp on lehtvedrudega vanakestele spiraalvedru sillakinnitustega raamide tegemine
Postitatud: R Nov 14, 2008 11:21
Postitas Lauri
Raputan tuhka pähe ja tunnistan, et oskagi pakkuda, millisel juhul see raami number nii oluline on?
Enda rahvamajaga olen mõned korrad ülevaatusel ja kord ka Tallinna ARK garaais (istmed +4) käinud, kuid raami numbri otsingud pole ametimeestel kunagi vilja kandnud. Heas usus on siis ka minu, kui omaniku esindaja poole pöördutud, kuid ei ole minagi juhatada osanud
Mingit tegevust numbri mitteleidmine siiani takistanud pole...
Postitatud: R Nov 14, 2008 11:31
Postitas tt
Lauri kirjutas:Mingit tegevust numbri mitteleidmine siiani takistanud pole...
tavaülevaatusel mitte aga arvelevõtmisel ja 5-> 7 istmed operatsioonil käidi traathari pihus ümber auto ja otsiti numbrit taga
