Lao tühendusmüük - soodsad metsaarvutid !
Postitatud: K Dets 02, 2009 21:37
Laost ilmus päevalagele kaks sinna seisma jäänud Panasonic Toughbook CF-52 "metsaarvutit".
Tegu semi-rugged e. nn. poolkarmide arvutitega. Mõned teist on seda Hr. Inseneeri võistlusautos "Toorik" näinud.
ka on sellise arvutiga Ladogal "Turist" klassis võisteldud.
Tegu aasta esimes pooles tootmisest maha võetud mudeli modifkatsiooniga, millel seismisest tulenevalt vaid 18 kuud garantiid järel.
Üks neist täiesti uus ja pakendis, hinnaks vaid 19500.- (koos KM)
Teine on võetud välaja kliendile demomiseks, hinnaks vaid 18000.- (koos KM)
Käte saab Tallinnast
info 5010599 või kristjan.vaarmann@skarcon.eu
Liikuvat pilti:
http://www.youtube.com/watch?v=sKvUUCFB1sM
tehniline info:
The CF-52 is the ideal all-round notebook when you are on the move or in the office. As a Toughbook, it comes up with a range of
ruggedised features protecting its key components against vibrations and even falls from a height of up 76cm*. The display is
surrounded by dampers and is mounted in a durable magnesium case. The hard disk drive is embedded in a shock-absorbing foam
and is connected to the motherboard by flexible cabling. The splash resistant keyboard and touchpad helps to stop water or any other
liquid from entering the casing and causing internal damage, while rubber port covers protect all sensitive external connections.
The CF-52 has a bright 15.4 widescreen LCD in 16:10 format with WXGA resolution particularly beneficial when displaying complex graphics. The maximum 4GB RAM (2 x 2GB DIMM), IntelŽ CentrinoŽ Duo processor technology, a weight of only 3.3kg and the integrated carrying handle provide maximum working
flexibility. Two Diversity WLAN antennas ensure optimal reception at all times, and finally, state-of-the-art energy-saving components combined with the CF-52s durable battery enable a running time of up to 7.5 hours.
As an ENERGY STARŽ Partner, Matsushita Electric Industrial Co., Ltd. has determined that this product meets the ENERGY STARŽ guidelines
for energy efficiency. Active Matrix colour display conforms to industry standards. Some displays may contain isolated illuminated or dark
pixels as an artefact of the manufacturing process (effective pixels: minimum 99.998%). RAM capacity calculated as follows: 1MB = 1,048,576 bytes. HDD capacity calculated as follows: 1GB = 1,000,000,000 bytes.
Mobile Computing IntelŽ CentrinoŽ Duo Processor Technology
Platform - IntelŽ Core 2 Duo Processor T7100 (1.8GHz, 2MB L2 cache, 800MHz FSB)
- Mobile IntelŽ GM965 Express Chipset
- IntelŽ Wireless WiFi link 4965 AGN (802.11 a/b/g)
OS Genuine WindowsŽ XP Professional or
Genuine Windows VistaŽ Business
RAM 1GB DDR2-667 SDRAM (expandable to 2GB + 2GB on project basis)
Graphic Chip IntelŽ GM965 graphics controller; UMA (WindowsŽ XP: max. 384MB; Windows VistaŽ: max. 251MB)
HDD 80GB S-ATA (shock resistant; withstands a 90cm drop)
Optical Drive DVD Multi Drive (DVD-R/RW & CD-R/RW)
LCD Bright 15.4 Active Matrix (TFT) colour LCD
1280x800 pixels (WXGA)
LCD Cabinet Magnesium alloy
BluetoothŽ Version 2.0 + EDR
WLAN IEEE 802.11a/b/g (max. 54Mbps)
LAN IEEE 802.3 10Base-T, IEEE 802.3u 100Base-TX, IEEE 802.3ab 1000Base-T
Modem Data: 56kbps (V.92) FAX: 14.4kbps
Sound Analog Devices AD1884 (conforms to IntelŽ High Definition Audio)
Integrated stereo speakers
Input Devices Touchpad and keyboard (both splash resistant)
Indicators 11 LEDs (2x Power, Battery, HDD, Multimedia Pocket,NumLK, CapsLK, ScrLK, SD, WWAN, Wireless ready)
Interfaces Serial (16550A compatible): Dsub, 9-pin
External display (VGA port): Mini Dsub, 15-pin
Headphones: Mini-jack, 3.5 DIA, stereo
Microphone: Mini-jack, 3.5 DIA, stereo
DC input: Jack
USB 2.0: 4x 4-pin
Firewire (IEEE1394): 1x 4-pin
Modem: RJ-11
LAN: RJ-45
Port replicator: 100-pin
Expansion Slots PC Card**: 1x Type I or Type II (3.3V: 400mA, 5V: 400mA)
ExpressCard**: 1x ExpressCard/34 or ExpressCard/54
SD Memory Card: 1x (Data transfer rate = 8MB per second)
Optional RAM Module: 200-pin, 1.8V, SO-DIMM, DDR2 SDRAM, PC2-5300 Compliant
Power AC Adapter: Input: 100V ~ 240V, 50Hz/60Hz; Output:15.6V, 8.0A
Battery: Lithium-Ion (11.1V, 7.65Ah)
Battery life: Approx. 7.5 hours (MobileMark 2005 60cd)
Charging time: Approx. 4.0 (Power on)
Power Management Standby function, ACPI BIOS
Software AdobeŽ Reader, installation program, DMI viewer, online reference handbook, Recovery Pro 6, PC Diagnostic
Security Features TPM (Trusted Platform Module TCG V1.2 compliant)
Password security (supervisor password, user password, hard disk lock)
Integrated hardware security lock slot
Dimensions (W x H x D) 355.7mm × 286.8mm × 50.7~51.9mm / 14.0 × 11.3 × 2.0 (including carrying handle)
Weight 3.3kg (including carrying handle)
Integrated Options Fingerprint Reader, Smart Card Reader, UMTS/HSDPA module
Accessories 1GB RAM module: CF-WMBA601G
2GB RAM module: CF-WMBA602G
AC adapter: CF-AA1683A
Battery charger: CF-VCBTB1U
Battery pack: CF-VZSU29AU
Port replicator: CF-VEB521W
Testing Standards MIL-STD 810F
Liikuvat pilti:
tehniline info:
DC input: Jack
USB 2.0: 4x 4-pin
Modem: RJ-11
LAN: RJ-45
