Defender 2011
Postitatud: R Dets 10, 2010 11:38
Land Rover Defender (2011) scooped
http://www.carmagazine.co.uk/Secret-new ... 1-scooped/
By Ben Pulman
Spy shots
14 June 2010 09:00
These pictures confirm that Land Rover is testing a new engine for the iconic Defender.
Didn’t the Land Rover only receive a new engine recently?
That’s true, though the switch to the Transit-derived 2.4-litre diesel did happen a few years back. This car is running a 2200cc oil burner, because the bigger 2.4 Puma engine apparently can’t meet forthcoming emissions regulations.
That means out with the 121bhp and 268lb ft 2.4, and in with the 2.2, but despite the smaller size expect a boost in power and torque outputs, plus performance, while the new engine should also help improve on the current car’s 27.5mpg and 274g/km CO2 output too.
We're not yet sure when the new engine will be introduced into the Defender, but Land Rover has a whole host of new product on the way in the next 12 months, including a facelifted Freelander, the new LRX and a new 4.4 TDV8 so it's another engineering matter to keep the Midlands team very busy.
Postitatud: R Dets 10, 2010 11:50
http://swipelife.com/2010/12/07/2011-st ... g-edition/
http://www.unfinishedman.com/the-2011-l ... r-defender
About a week ago we wrote an article on the awesome and luxurious Land Rover Defender 90 Yachting Edition; that post turned out to be quite popular, which is understandable because of the awesomeness of the Defender. Today we bring you the 2011 Land Rover Defender line-up.
The 2011 Land Rover Defender gets subtle styling updates, which will probably be only noticed by the die-hard Defender fans. The 2011 Defender comes in 90 different variations with long and short wheelbase models.
As cool as the Defender is on the outside, on the inside it’s a different story. The Defender is powered by a “not so awesome” 2.4 liter diesel engine that produces a wimpy 120 horsepower and 251 pound-feet of torque. The horsepower numbers are pretty depressing considering how tough the Defender is but I guess the torque numbers some-what make up for it. The diesel engine is mated to a 6-speed manual transmission and it comes with permanent four-wheel drive.
As expected, this heavy beast is pretty slow with a top speed of only 82 miles per hour (132 km/h) and a 0 to 62 mph sprint crawl in 15.9 seconds. But then again, this is a true off road vehicle and is meant to go places where your average Hummer can only dream of. The Defender can climb slopes of 45 degrees and descend slopes of 49 degrees and it can stay upright on slopes of 35 degrees, with ease.
The 2011 Land Rover Defender will stay in production until 2013, in current form and then a new more modern version will be released. I’m hoping it will still retain the same shape and off road capabilities but with a lot more horses. Hopefully Land Rover will do what Mercedes did with the G-Wagon, which has been updated continuously over the last five decades while retaining the same rugged shape.
