Siin siis õli soovitus ja täpsed margid:
http://www.castrol.com/castrol/sectionb ... Id=7073092
Ülejäänud vidinaid võid küsida
http://www.allmakes.ee
Engine (DT) EDGE 5W-30 (a) 7.2
Magnatec 5W-30 A1
Manual Transmission Syntrans Multivehicle 75W-90 2.7 (b)
Automatic Transmission Transmax Dex III Multivehicle 9.8 (b)
ATF Dex II Multivehicle
Differential Universal 75W-90 1.7 (c)
Axle EPX 80W-90
Coolant (50%) - (d) 11.5
Brake Fluid - (e)
Grease Points Multipurpose Grease
a. Engine oil viscosity recommendations TD5 (Storm) diesel engines and V8 petrol engines from 2002: -30°C to 35°C, 5W-30; -30°C to 40°C, 5W-40/5W-50; -20°C to 35°C, 10W-30; -20°C to 40°C, 10W-40/10W-50; 0°C to 40°C, 10W-60; refer to individual model handbook for early models
b. Transfer box LT 230/230Q: 2.3 ltr, Universal 75W-90 / Axle EPX 80W-90. Models prior to Jan 98, Universal 75W-90
c. Differentials front and rear
d. Cooling systems. Use Antifreeze at a concentration of 50% or one part Antifreeze with one part water. Ethylene glycol antifreeze using organic acid technology inhibitors only recommended
e. Manufacturer's recommendation, Refer to main dealer
1. Power steering (where fitted): Current models, Transmax Dex III Multivehicle / ATF Dex II Multivehicle; older models, Refer to Technical. Discovery II, Discovery III 2002, Range Rover 2002; use only recommended fluids. Fluid is dyed green and used in common reservoir with ACE system where applicable.
Engine - Miles Max 6000
Engine - Km Max 10000
Engine - Months Max 6[/url]
