Webastole kell ja pult külge
Äkki saab siit häid ideid:
http://www.landroverclub.ee/foorum/view ... ht=webasto
Seda friika lehte olen näinud, sealt sain ka idee. Kuid kas D3-me puhul on asi nii lihtne.
Kui eelmisel aastal küsisin Webasto maaletoojalt (autoekspert) siis vastus oli ümmargune 0, nemad ei paigalda ja ka siis kui Inchcape on enne ümber programmeerinud ei suutvad nad midagi teha vaja veel mingeid LR orignaal lisavidinaid.
Nüüd tuhnides interneti avarustes, leidsin sellise koodiga jubina WEBASTO FBH TIMER KIT 1533 FOR LANDROVER DISCOVERY 3
Discovery 3 Engine: 2.7L(TDV6) Diesel
VIN-range: 5A300167 Onwards
Range Rover Sport (LS) 2007- Engine: 3.6L(TDV8) Diesel
Markets: Russia only
Section: 412-02b
Summary:
A customer may report a concern of poor engine starting in ambient temperatures below -25°C.
Cause: The Discovery TDV6 diesel engine is specified to start at ambient temperatures of -25°C and above. In Russia, the vehicles can experience temperatures below this threshold.
Action: On a customer concern basis only regarding the above, refer to the Service Procedure detailed in this bulletin to install an auxiliary heating timer to the fuel fired booster heater (FFBH), which provides additional engine pre-heat prior to starting. The procedure calls for the use of a special tool (LR-130) when drilling holes in the interior lamp unit. The tool is available free of charge for the first tool order (subsequent orders for the tool will be chargeable) from SPX Service Solutions via the contact details below:
(details removed)
Parts Required:
Description Part Number Quantity
Engine pre-heater timer kit JEC501490 1
Webasto tootja leht pakub ainult Friikale antud kiti.
Helistasin Autoexperti ja ootan nüüd vastust, telefoni teel sain nii palju targemaks, et kunagi pakuti kuid nad ei ole kindlad kas enam saab seda lisa Disco 3-le.
Täiendatud
Venemaal müüakse neid kite endiselt, http://lr-mag.ru/catalog.html?itemid=15 ... =JEC501490
Section: 412-02b
Summary:
(details removed)
Parts Required:
Täiendatud
Viimati muutis Renek, R Sept 20, 2013 09:27, muudetud 1 kord kokku.
Disco4 2011 3.0 HSE
Disco3 2008 2.7 HSE
Disco3 2008 2.7 HSE
Kas sellest pole abi:
http://www.disco3.co.uk/forum/topic9796.html
http://www.disco3.co.uk/wiki/Special:Se ... asto&go=Go
http://www.disco3.co.uk/wiki/Modifications
Mõtlesin, et nüüd, kus on jupp aega möödas, kirjutan oma kogemustest webastole "kella" lisamisega:
Üldiselt võib öelda, et Tallinnas läks otsimisega üsna kaua aega, sest enamus kohad ütlevad: " Jah, saab ikka! Mis auto teil on? Discovery!..noo, me päris kindlad ei ole, aga võime proovida!"
Lõpuks leidsin sellise koha nagu www.carholding.ee ning sai peale pandud danhaus'i gsm controller.
Kauplema ei hakanud ning koos käibega oli 687eur.- (ilmselt ei ole saladus).
Oli algul mure, et kliima ei lülitunud ümber tavareziimile pärast auto käivitamist, kuid see mure sai lahendatud.
Paraku ilmes ka pärast seda, et webasto põleti oli läbi ning see sai inchape'is vahetatud 550euri eest.
Ühesõnaga, nüüd asi toimib, kuid talve ei ole, rsk!
Siukse raha eest ma võin ise tulla igal hommikul su autot käivitama (ja lume võin ka maha lükata)Taavi240 kirjutas:Mõtlesin, et nüüd, kus on jupp aega möödas, kirjutan oma kogemustest webastole "kella" lisamisega:
Tere!
Panen ka siia üles Webastoid puudutava info, mida sai käsitletud Range Roverite ja Discode alamrubriikides.
Tartu LR töökojas oleme Webasto lisasoojendusi seisusoojendusteks teinud erinevates variatsioonides. Kasutame Webasto osasid ja tarvikuid. Kõige soodsam lahendus maksab 460 ja süsteemi juhib autosse paigaldatud programmkell. Sellest moodsam ja mugavam on Webasto juhtimine puldiga, hind 770. See ei ole lihtsalt on-off pult, vaid displayga suhtlusvahend auto ja peremehe vahel. Ja veel täiuslikum versioon on käivitamine mobiiltelefoniga, hind 850 + SIM kaardi maksumus. Eelsoojenduse lülitumisel hakkab madalatel pööretel tööle ka salongi soojenduse ventilaator, mis esiklaasi puhtaks puhub. Kui klient seda ei soovi, paneme süsteemi tööle ilma ventilaatorita. Töö teostamine võtab aega sõltuvalt valitud süsteemist 4-6 tundi. Enne Webasto täiustamist lisavidinatega kontrollime ära kogu olemasoleva süsteemi laitmatus töökorras olemise. Rikkis süsteemi ei sunni lisaseadmed tööle ka kõige parema tahtmisega.
Juhul, kui ei ole soovi kellasid-pulte-mobiilivastuvõtjaid juurde lisada, aga lisasoojendus tõrgub, vaatame ahju üle ja teeme korda ning sooja tuleb jälle.
Liiast pole korrata, et mootor, mis ei saavuta ettenähtud töötemperatuuri, kulub ise intensiivsemalt, kulutab palju kütust ja ka teie närve auto külma salongi ja läbipaistmatute klaasidega Idea
Heikki
_________________
Heikki
_________________
"Inglise dentelmenide" kohtumispaik Tartus. Professionaalne diagnostika, hooldus ja remont. TEL: 56883950, 55993078
