M: Warn Tabor 9k vints
Vahetan, pakun teenuseid, rendin.
Suletud
toilu
Postitus Postitas toilu »
Müüa siis uus Warn Tabor 9k vints:
Tabor 9K Winch Specification
Rated Line Pull: 8820 lbs. single-line
Motor: 4.3 hp, Series Wound
Geartrain: 3-Stage Planetary
Remote Control: Remote switch, 12' lead
Gear Ratio: 216:1
Clutch (freespooling): Sliding Ring Gear
Brake: Internal Automatic
Weight: 77 lbs.
Wire Rope: 100', 5/16" diameter
Fairlead: Roller
Recommended Battery: 650 CCA minimum for winching
Winch Dimensions: 20.89" L. x 6.3" D. x 6.4" H.
Mounting Bolt Pattern: 10.0" x 4.5" On Center
Battery Leads: 2 gauge, 72"
hind: 450 €
Metsas näme rsk!
toilu
Ja müüdud ta saigi :)
Lukku
Metsas näme rsk!
Suletud
