Discovery perekond?
Discovery perekond?
Land Rover has officially confirmed that the Discovery will become a range of different-size models in its own right for 2015.
Allikas:
Land Rover Owner magazine
http://www.youtube.com/watch?v=ouy-L_HB-zU
							Allikas:
Kuulujuttude alusle sünnib mingi järjekordne Evoque sarnane peletis, eriti teades kes praegi JLR  peadiseiner on
The seven-passenger Discovery Vision Concept is loaded with innovation, including Gesture Control, Remote Control Drive, laser headlights, Smart Glass, Laser Terrain Scanning and Transparent Bonnet. Most, if not all of the technology will trickle out over the next decade on Land Rover's production vehicles.
http://www.autoblog.com/2014/04/15/land ... york-2014/
from disco 2 disco
						Samsugune "seebiluts" nagu Evoque.  Varsti peab kõigi LR-i mudelite  tuvastmsieks minema juurde ja kapotilt või luugilt lugema millegategu.  Eemalt vahet teha pole võimalik.
Kõvasti tehnikat sees. Kõige huvitavam tundub olevat Remote Control Drive
This feature enables the driver to manoeuvre the car at very low speed while not actually seated inside it, via the removable secondary rotary on the centre console, as well as via a smartphone or tablet. Applications include:
 extreme off-roading, where it is sometimes safer and easier to inch the vehicle over obstacles from an outside vantage point,
 coupling to a trailer, or
 driving through gates, where the driver can avoid repeatedly getting in and out of the vehicle by simply opening the gate and letting the vehicle drive through via Remote Control Drive, before shutting the gate and re-entering the vehicle.
Remote Control Drive has a simple, easy-to-use interface, encrypted access and operation only via the vehicle's localised WiFi, putting the power of autonomous vehicle control safely and securely in the driver's hands.
Another enhancement to the driver's capability is Laser Terrain Scanning. The Discovery Vision Concept's foglamps are capable of emitting infrared lasers, and these are used to scan the ground ahead, map the terrain and display the mapped imagery on the hi-definition cluster screen, providing the driver a vital visual reference and helping him understand the lay of the land while driving in challenging off-road conditions.
Laser Referencing
Both on and off the road, the Discovery Vision Concept's laser technology capability offers an additional resource: Laser Referencing. Here, the laser light is tuned to specific colours in the visible spectrum and used to project visible images onto the road. This has numerous useful applications, including projecting warning triangles onto the tarmac behind the car for other motorists to see in the event of a stoppage, or projecting reference points onto roads, walls or any terrain, in order to help the driver to judge tight gaps and to park or drive in congested spaces.
Transparent Bonnet
Another way of providing the driver with enhanced visibility and a greater understanding of the terrain is Land Rover's innovative Transparent Bonnet system. Cameras under the vehicle's grille send video of the terrain being traversed, projecting it to the Head-Up Display in the windscreen. By overlaying the imagery through the driver's line of sight on the HUD covering the bonnet area, the system effectively creates a 'see-through' bonnet view of the terrain and the direction of the front wheels, thus improving visibility and enhancing driver confidence.
Terrain Response
The next generation of Land Rover's iconic multi-mode terrain-tackling system links up and networks all these advanced capability technologies, as well as Hill Descent Control, wet grass traction control, auto hi/lo, Low Speed Steering Assist and Wade Aid.
Terrain Response not only analyses the type of terrain being traversed  snow, ice, mud, grass, water, rocks, ruts, tarmac, gravel, sand, inclines and so on  but also proactively anticipates upcoming terrain via Laser Terrain Scanning and forward-facing camera sensors, and instantly engages the appropriate system to best respond to that type of terrain and situation.
Wade Aid is a new sensory wading system that uses lasers to judge the depth of water ahead before the vehicle even begins to wade, and informs the driver of the feasibility of the intended wading manoeuvre.
The Discovery Vision Concept's all-terrain capability enables differing levels of driving enhancement:
 All Terrain Progress Control: A low-speed all-terrain cruise control that vectors torque to enable semi-autonomous off-road driving at a steady speed.
 All Terrain Coach: for the more manually inclined. Here, the driver chooses from a menu the type of terrain being traversed and then gets a recommendation as to which off-road system ought to be activated for the best response.
 Enhanced All Terrain Coach: marks a specific route across a terrain map rendered on the console display via Terrain Scanning, and suggests the appropriate systems to help navigate it step-by-step.
Laser Referencing
Transparent Bonnet
Terrain Response
from disco 2 disco
						Küsimus pole mitte ilus, vaid isikupärasuses. Kui vanasti tundis iga LR mudeli kilomeetri kauguslet ära, siis nüüd peb sõna otses mõttes auto pealt lugema mis mudleiga tegu on. Evoquet ei suuda mu silm siiani liikluse eemalt Kia-de, Hyundai-de ja muudesam disiniga seepide seat eristada.sigaelmar kirjutas:Küll silm ära harjub. 2003 aastal kui BMW tuli välja uue 5 seeria BMWga, arvasid ka kõik et appi kui inetu auto aga täna mõjub selle disain siiani värske ja nägusana.
Eisndus ei tea siin üldse suurt midagi. Ka praeguse Defenderi suurtest tehnilistest uuendustet polnud nad midagi kuulndu ei plaani neist neist ka avalikult rääkida.Renek kirjutas:Ei tasu veel kurvastada, see on siiski disco mis asenda freelanderit. Suure venna kohta inf puudub.
Kusjuures ka esindus ei ole kursis milline uus suur Disco tuleb, ka nemad loodavad, et mitte Sport ja Vogue sarnane väga ümar pall.
- Chopper
- Rohkem muda- PALUN!
Täpselt minu mõte - hetkel saad aru kas freekas rr või disco, aga varsti hakka silmi pingutama et eest lugeda millega tegu.landy kirjutas:Küsimus pole mitte ilus, vaid isikupärasuses. Kui vanasti tundis iga LR mudeli kilomeetri kauguslet ära, siis nüüd peb sõna otses mõttes auto pealt lugema mis mudleiga tegu on. Evoquet ei suuda mu silm siiani liikluse eemalt Kia-de, Hyundai-de ja muudesam disiniga seepide seat eristada.sigaelmar kirjutas:Küll silm ära harjub. 2003 aastal kui BMW tuli välja uue 5 seeria BMWga, arvasid ka kõik et appi kui inetu auto aga täna mõjub selle disain siiani värske ja nägusana.
LR Disco III 2,7 2007
						Blinb-bling perekonna sünd...
http://newageofdiscovery.landrover.com/ ... -discovery
