Milline õli RR II sildadesse ja käigukasti?
Tervist. Milline õli läheb RR II 2,5 diisel 2000 aasta automaatkast sildadesse ja käigukasti ning kui suur kogus?
RR II 2,5 D
Series III 79 a. 2,25 B
Discovery IIA td5
Defender 110 td5
RR III Vogue
Discovery IIA td5
Defender 110 td5
RR III Vogue
- LittleSuzi
- ELRK liige
Castrol lehe soovitus:
Land Rover
Range Rover
Range Rover 2.5 TDi (1995-2001)
Engine Capacity 9,5 liter(s)
Use: Normal
Service intervals:
Change 10000 km / 6 months
EDGE Sport 0W-40
EDGE 5W-30
Magnatec 5W-40 C3
Use: Severe
Service intervals:
Change 5000 km / 1 months
EDGE Sport 0W-40
EDGE 5W-30
Magnatec 5W-40 C3
Transmission, automatic 4/1 ZF 4HP 22 Capacity 9,7 liter(s)
Use: Normal
Service intervals:
Change 40000 km / 24 months
Transmax Z
ATF TQ DIII
Transmission, manual 5/1 R380 Capacity 2,4 liter(s)
Use: Normal
Service intervals:
Check 20000 km / 12 months
SMX-S 75W-85
Differential, rear Capacity 1,7 liter(s)
Use: Normal
Service intervals:
SAF-XO 75W-90
SMX-S 75W-85
Syntrax Universal
Differential, front Capacity 1,7 liter(s)
Use: Normal
Service intervals:
SAF-XO 75W-90
SMX-S 75W-85
Syntrax Universal
Transferbox Borg Warner Capacity 2,4 liter(s)
Use: Normal
Service intervals:
Transmax Z
ATF TQ DIII
Hydraulic brakes/clutch system
Use: Normal
Service intervals:
Change 60000 km / 36 months
Response DOT 4
Power steering Capacity 1,7 liter(s)
Use: Normal
Transmax Z
ATF TQ DIII
Cooling system Capacity 11,3 liter(s)
Use: Normal
Service intervals:
Change 36 months
Antifreeze SF
Antifreeze NF
Antifreeze
Land Rover
Range Rover
Use: Normal
Service intervals:
EDGE Sport 0W-40
EDGE 5W-30
Magnatec 5W-40 C3
Use: Severe
Service intervals:
EDGE Sport 0W-40
EDGE 5W-30
Magnatec 5W-40 C3
Use: Normal
Service intervals:
Transmax Z
ATF TQ DIII
Use: Normal
Service intervals:
SMX-S 75W-85
Use: Normal
Service intervals:
SAF-XO 75W-90
SMX-S 75W-85
Syntrax Universal
Use: Normal
Service intervals:
SAF-XO 75W-90
SMX-S 75W-85
Syntrax Universal
Use: Normal
Service intervals:
Transmax Z
ATF TQ DIII
Use: Normal
Service intervals:
Response DOT 4
Use: Normal
Transmax Z
ATF TQ DIII
Use: Normal
Service intervals:
Change 36 months
Antifreeze SF
Antifreeze NF
Antifreeze
- LittleSuzi
- ELRK liige
