ARK+EW/EU seadused ja LR raami vahetus
Lugedes seda:
http://forum.4x4.ee/viewtopic.php?t=13657
tekkis küsimus, kas meil on võimlik legaalselt auto alusraami vahetada (kui raam ostetud ametlikult ja paberitega)? Osades EU maades saab.
Pole jõudnud väga meie banaanivabariigi seadustesse sukelduda.
koopia 4x4 foorumist:
mina küsin:
Mida ütleb sellepeale ARK? Ehk kommenteerite kui, te seda foorumit niikunii igapäevaselt loete. Foorumisse postitamiseks peab end kasutajaks registreerima, kasutajaks saab registreerida siin.
mina küsin:
emamaalt vastatakse:Is there any paperwork required in UK? New chassis number etc? Do you have to show the car in DVLA before/after?
Also could you scan and post here any certificates & paperwork included with new chassis?
Just wondering, could we do that legally in Estonia, our DVLA is quite strict in that matter - VIN and chassis numbers have to match.
Kokkuvõtteks saab raami tellides teatada oma vana kerenumbri mis stantsitakse uuele raamile.you can order the replacement chassis stamped with your existing chassis number, because its a direct replacement (not modified) theres no problem doing this officially. Trevor kept the piece of the original chassis that had the numbers stamped on so he can prove (if anyone official ever asks) that the old chassis had been destroyed.
The replacement chassis is so good the only difference is the galvanising (and the fact its construction is corner welded instead of 2 "C" sections) The replacement chassis can be ordered in different thicknesses if you want something stronger (heavier) or you can order a coil sprung 88" chassis for a series Landrover allowing you to change to Range Rover/Discovery/Defender axles and suspension.
There are no certificates that come with the new chassis but there is a receipt and this can show that your exisiting chassis number has been stamped in (if you want). Its a pretty normal thing to do here, it helps the car keep a good value if its not rusty! Very Happy
Sain aru, et raami tegijad on kolmas partei, pakuvad soovikohast raaminumbrit lisateenusena.LR90 kirjutas:Kokkuvõtteks saab raami tellides teatada oma vana kerenumbri mis stantsitakse uuele raamile.
Kui uus raam tuleb vana VIN- koodiga, milleks
Sa sinna ARK-i pead minema
ARK -i angaari leivanumber ju LR raami nähes silmad punni ajada: issand jumal KEEVITATUD raam!!! Seleta siis neile, et sellised nad on aegade algusest olnud
Õige point. Seega, kui VIN-koodi plaat ja raaninumber klapivad on kõik legaalne. Raam nagu iga teine varuosa.LR90 kirjutas:Kokkuvõtteks saab raami tellides teatada oma vana kerenumbri mis stantsitakse uuele raamile.
Viimati muutis landy, N Nov 13, 2008 18:32, muudetud 1 kord kokku.
Raputan tuhka pähe ja tunnistan, et oskagi pakkuda, millisel juhul see raami number nii oluline on?
Enda rahvamajaga olen mõned korrad ülevaatusel ja kord ka Tallinna ARK garaais (istmed +4) käinud, kuid raami numbri otsingud pole ametimeestel kunagi vilja kandnud. Heas usus on siis ka minu, kui omaniku esindaja poole pöördutud, kuid ei ole minagi juhatada osanud
Mingit tegevust numbri mitteleidmine siiani takistanud pole...
Valge Defender110 e. Rahvamaja
