Dsicovery 2-le keskdifri lukk!
Aegumatud tarkuseterad
The 2004 Disco2 is the only Disco2 that comes from the factory with a CDL shifter, and what an effective and smooth mechanism it is. We have heretofore advocated the fitment of a Disco1's CDL shifter as the most elegant and quasi-factory method to lock the Disco2's transfer box. However, we now opine that the 2004 Disco2's CDL shifter is a far superior method and is really the only way to fly. The cable-actuated 2004 CDL shifter is noticeably smoother in operation than the hard linkages employed on the Disco1 CDL shifter and the lack of hard linkages noticeably attenuates drivetrain noise and vibration inside the vehicle. Our CDL Kit is composed of all Land Rover Genuine Parts and contains everything one needs to lock one's CDL-ready transfer box, including the shifter knob, 2004 CDL shifter body, cables, fasteners, and other appurtenances. (Not included is the 2004 CDL placard, as this part is not available separately through Land Rover parts channels.) If your transfer box is not CDL-ready, i.e., not readily lockable, our CDL Kit is not suitable for you. Rather, our CDL Kit is for the Disco2 that already has a readily lockable transfer box but lacks the means to lock it.
Tellida saab:
https://www.expeditionexchange.com/kit/
Land Rover Genuine Parts 2004 Disco2 Center Differential Lock Kit (EW21) $700
Varianat 2 !
http://www.boothroyd.com/cdl.htm
Varinat 3!
http://www.amv.com.au/SeriesIIDifflock.htm
Variant 4!
http://www.offroadbutikk.com/acatalog/O ... se_59.html
Central Diff Lock Kit
Solenoid Activated Central Diff Lock
When the Disco Series 2 was released Landrover decided that the Central Diff Lock (CDL) was not needed as they had introduced Electronic Traction Control. This kit will reintroduce the ability to lock the centre diff via a switch on the binnacle.
This can only be fitted to a Disco II that has the spigot on the transfer case. Landrover decided to phase this out from mid 2001. Please check that you have it on your transfer case before ordering; Click on the link below to check on where to find it.
Key Benefits:
*Be able to lock the centre diff when off-roading, improved traction
*Can be used with or without Electronic Traction Control (ETC)
*No body will know that you have it fitted from within the cabin
*Can be used in Hi or Low range
Variant 5 !
http://www.erikburrows.com/index.php?no ... DL+Linkage
Varinat 6!
http://safarigard.com/pdf/difflokpdf.pdf
Discovery II ja IIA
If you have the diff lock stud on your unit you will only require the linkage parts, to determine this you will need to find the transfer case serial number and check it starts with
41D LT 230SE
42D. LT 230SE
If it starts with
61D
62D
69D
70D
then you will need the diff lock parts to go in the transfer case.
vaata lisaks http://www.aulro.com/afvb/good-oil/39956-cdl-d2s.html
http://www.discovery2.co.uk/diff_lock.html
Leidsin veel sellise kirjatüki.
