Pakkuda mõistliku ekraani ja pimedas nägeva kaameraga "tagurdamis komplekt".
Kaameral 7 infrapuna LEDi, Monitoril 2 videosisendit.
Müün kuna omal Rangesse ikkagi see ei sobi nii nagu tahaks.
Hinda küsin 60, Asi asub Tallinnas, ning asjad on tutikad.
Jüri - 55510064 - jyri@nordiclure.ee
Fäänci juttu ka:
Main Features:
- Helps you see what\'s hidden behind your car when parking or reversing.
- With a stand holder which has adhesive sticker in the bottom for sticking it to your car firmly and stably.
- Available for VCD / DVD / GPS / CAMERA.
- High resolution picture & Support full color LED backlight display.
- With rotatable screen & Display black screen on no signal.
- The OSD menu always in a readable position whatever the image is mirror or normal.
- With 2 video inputs, White video cable connects to car rear view camera, Yellow one to other video equipment.
- Low power consumption and easy to install.
TFT-LCD Parameter:
- Rated Voltage: 12DCV
- Display Resolution: 480 x 272 Pixel
- Display Rate: 4:3 / 16:9
- Response Time: 30ms
- Video Input: 2 ways
- Work Temperature: Between 20 degrees celsius and 70 degrees celsius
Color: Black & Silver
Screen Display Size (L x W x H): 125 x 13 x 83mm
Package Size (L x W x H): 135 x 100 x 65mm
Screen Net Weight: 164g
Package Weight: 238g
Note: The system can not stop car automatically when it detect a barrier.
Car Rear View Camera:
Main Features:
- High-definition & High-sensitivity - 420TV lines.
- Waterproof, Weatherproof, Shockproof function.
- Support night vision.
- 170 degree wide viewing angles.
Image Sensor: Color CMOS / CDC
TV System: NTSC / PAL
Effective Pixels:
- NTSC: 728 x 628 828 x 686
- PAL: 628 x 586
Scanning System: 2 : 1 Interface
Sync System: Internal
Resolution: 420 TV lines
Lens Angle: 2.8mm / 120 ~ 1.8mm / 170 Degree
Sensor Area: 5.961 x 4.276mm
Video Output: 1.0Vp-p, 75ohm
S / N Ratio: More than 48db
Waterproof: IP68
White Balance: Auto
Power: 60mA
Consumption: Max 300mA with IR on
Power Supply: DC 12V
Operating Temperature: - 20 ~ + 80 Centigrade
Storage Temperature: - 40 ~ + 80 Centigrade
Camera Net Weight: 54g
Package Weight: 180g
Approved: CE / FCC
