Tervist.
Vabandan kui vale asja alla postitan. Mure nimelt selline soovin osta Range rover p38 sildadele aeglasemad ülekanded kas keegi kunagi tellinud või äkki kellegil olemas ja soovib müüa. Nimelt on need sillad kasutusel ET1 autol aga ülekanne liiga kiire (3.54) sooviks panna 4.75 pea ülekannde . Kuidas kindel olla et kas on long nose või short nose differ? Leidsin netist ühe versiooni oskab keegi kinnitada et sobivad?https://www.johncraddockltd.co.uk/kam54 ... -rear.html
Tänud.
Vajan abi ostuga.
Re: Vajan abi ostuga.
Land Rover Differentials - Technical Overview
For the vast range of Land Rovers there are 2 x Types of Differentials, 'Long Nose' and 'Short Nose'.
With a few exceptions most Series LRs, LR 90s, Discoveries, Defenders, and Range Rover Classics all have 'Long Nose' Differentials.
'Short Nose' units are in Range Rover P38s and LR TD5 110s and 130s which have Short Nose Rears and 'Long Nose' fronts.
The other Differentials are 'Salisbury Units' and are easily identified as they have a bolt on Cover on the rear of the axle pan.
Long, Short, and Salisbury Differentials are NOT interchangeable.
Long Nose Differentials are either 4.7:1 Ratio and 10 Spline Drive (Series LRs), or 3.54:1 Ratio, for pretty much everything else which can be either 10 or 24 Spline Drive.
