Hüdrofobiseerimine
andrus
Hüdrofobiseerimine
Postitus Postitas andrus »
Küsimus selline, et kuna autole tekkis pooleldi juhuse tahtel snorkel külge, siis mida oleks otstarbekas võtta ette auto elektrisüsteemide veekindluse tõstmiseks? Autoks on defender td5 mootoriga. Mida on kogenenumad inimesed teinud näiteks kõrvalistuja all pesitseva ajuga jne?
The only downside of the Td5 is wading as all the electrics are under the seat. You can do some waterproofing to improve matters however I don't think I would take my Td5 wading with the same confidence that I do my Tdi. In the event of the electrics getting wet or damaged, the Td5 apparently has a limp home facility which would allow you to keep moving but at low speed. Off road I prefer my Tdi 110 due to it's longer wheelbase and mods however on road the Td5 is tops.
If your bush driving involves a lot of water crossings the Td5 might not be the best choice however if it's predominantly dry it would be mine. In terms of economy and power it is excellent.
allikas:
http://www.landyonline.co.za/market_place/reviews.htm
Heater box fills up with water in deep river crossings if you forget to tape the intake up, but the heater fan works fully submerged, so that's a bonus if you want to pump water into the cabin.
allikas:
http://www.carsurvey.org/review_37276.html
Samas ei ühtegi ostseselt head nõuannet... :cry:
Sonorkel on ÜHVA (üks väga hea asi)!. Mina soovitaks autos pidada mõõdupulka (labidat näiteks) Kummisaapad poleks kah paha, et enne veetakstuse läbimist läbikäia jälgsi ja pulgaga põhja sorkida. Suurematel veekogudela kasutada paati, see aasta on teadaolevalt 3 (kolm) autot uut aju küsinud seoses ülemääraste SPA protseduuridega. hinnad alates 11 k krooni.
Pärast mõningaid isiklike õppetunde olen selliste vahendite tõhususes veendunud.
